Hi
I do some electronics work. For safety sake I was wondering if there's a type of panic button I could use to cut off the supply off a socket which I'm going to install. It will be run off an existing double socket. Once this panic button is pressed the power should stay turned off until I reset it. The soldering station am using runs off a 13A plug top.
