P
pjb1
Hi Guys
need your advise on certifying when doing an installation on on a conservatory ie put a rcd protected fcu in and existing ringmain.Then feeding socket via the rcd on a radial circuit adding to that radial a fcu for the light. Which certificate should i be issuing.
As this is an addition to and existing ringmain would i be wrong or right giving them a minor works certificate?
