Part F building control notification | on ElectriciansForums
Discuss Part F building control notification in the UK Electrical Forum area at ElectriciansForums.net
Aaron b
Mentor
England
Hello, I understand that from the 15th of June testing and commissioning of vents and fans is now compulsory and that also since last year any works regarding fans needs to be notified to building control under part F.
I assume that this can be done as a NAPIT contractor registered with EAS. I've had a look through napits Ventilation Certificate, the details in appendix C of part F and the Domestic Ventilation Compliance Guide and the commissioning seems overly onerous and requires specialist equipment. Is anyone here doing part F notifications, commissioning or the full ventilation survey that appears to be required? I'm either thinking of blaming the plumber or offering it as a separate service...
Surely if it can hold a piece of toilet roll in place it's doing its job correctly
I would say 8 out of 10 fans I come across will hold a single sheet of andrex up , however 7 of those 8 fans are just sucking air into the the loft space 🙃
@Dustydazzler I'd say I've only fitted around 20 bathroom fans in my time, all for friends and family, about 5 new and the rest replacements and I've only came across it once. Incredibly lazy approach probably speaks volumes for the rest of their work.
In 25+ years of doing Domestics I have probably replaced around 500 fans and I would say a huge chunk were never vented properly, either straight into the loft (no ducting) or a short bit of plastic duct just buried under some insulation. I know its not the end of the world just shoddy
I'v ducted the shower ceiling fan into the top of the cold water tank, seems a waste to vent it to air through the roof.
It’s not just water vapour being sucked away. There will be smells, gasses, ahem
You’ll be using that water to clean your teeth…..🤢
Reply to Part F building control notification in the UK Electrical Forum area at ElectriciansForums.net
