Part P Again | on ElectriciansForums
Discuss Part P Again in the Australia area at ElectriciansForums.net
Jay Sparks
Mentor
Bratford
Hi guys, Just a few questions on the dreded part p regs.
In a kitchen there are 5x 12v down lights each with there own transformer. The customer wants to add 3 more to the circuit.
Q1) Although its a minor works, it is still notifyable, so would you still fill out a Minor works cert or a EIC? Also if you Filled in the EIC, on the shedule of inspections cert, would you tick the SELV box as each down light has a transformer and no other light does?
Q2) How would you IR test the circuit because all the other lights are normal, except the 8 in the kitchen. Would you disconnect each transfomer or just connect Line and Neutral together and test to earth?
Q3) If you discconected each transformer how do you test them? I know it has to be at 250v dc but where or what do you test?
Any input would be greatfuly accepted.
Reply to Part P Again in the Australia area at ElectriciansForums.net
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
