Part p again | on ElectriciansForums
Discuss Part p again in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
South east
Ive just decided that i was going to take a look at the Part P document online. Ive read it, and there are some interesting points id like some clarification on.
1.21 and 1.22 state that a notifiable job should be notified to the local authority beofre the work starts. They then state that if you are qualified to test and fill in an installation certificate to BS7671, you should do so. the local authority will then decide what action (if any) is needed. They may take your qualifications into account.
Does this mean that i can notify the council, then carry out the work and then inspect/test it and hand them the cert/results?
It doesn't mention anywhere about getting permission from the council, just notifying them.
Also 1.26 states that the building control may decide to undertake some of the tests themselves, or to sub it out. such tests will be carried out at their expense, not at the expense of the householder.
the above reg refers to DIyers and contractors not qualified to carry out test/inspect to BS7671.
Have a read yourself, but i think that this is very open to interpretation, and a decent lawyer acting on behalf of a good sparks who has carried out work comepetently and to BS7671, would be able to defend it.
what do you all think?
Anyone can do Electrical work as long as LABC knows about it, and it is correctly certified on completion. There is a fee, and its usually quite large.
Cheers........Howard
once youve notified them, and done the work, and tested and handed in cert/results along with quals, then how would they get cash out of you? you have complied with part p, as you have notified them, and inspected/tested to ensure it is safe to BS7671.
id be interested to hear what others think?
Indeed,
It is the responsibility of the LABC to make sure your work complies.
However, the cost of this is normally passed on to you or the client.
Reply to Part p again in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks all. Sounds like I hadn’t completely missed the point on what Part P needs at least. I’m not so much worried about a knock on the door as...
It applies to commercial if it shares the same supply as a dwelling.
