E
eyeball
Hi all,
I'm due an assessmnt for the first time at the end of the month. Now I dont work day today doing electrics, just normally do it on my own properties but I want my part P just incase I decide to to other work.
The assessor will want to see what work ive done and probably what I'm doping at present. The problem is all my work so far has been simple swaping of sockets and other fittings with no notifiable work. So I was thinking of rewiring my garage/ workshop. It also needs rewiring as its not ideal at present.
This is what I'm thinking....
At the moment there is only one consumer unit that is rcd prtoected and this is in the house so I'm thinking of running a 10mm twin and earth under the floor from the front to the back of the house, then chase out the drive to go to the garage. This run is about 15 meters max. Then install a 2 was c/u with a 63A main. Then this will just feed the 3 double flouresents for lighting and poss 6 double sockets. There is no plan of using high current equipment in the workshop, just battery chargers and a small electric heater. I'm thinking of poss having a summerhouse at some point and this will be at the end of the garden behing the garage/workshop so I'll be wanting to put lights and power in there aswell but nothing heavy again.
The main consumer unit in the house will feed the 10mm T&E via a 40 Amp mcb. Does this project sound ok for my asssessment or do you reccommend anything else?
Cheers,
Paul
Cheers,
Paul
