T
Tunnel Lee
Hi,
I last worked in the UK in 2006, I did a little bit of Part P work before then, but the regs and laws seem to have moved on quite a bit since 2006 and I've been out the loop.
I plan to do some work at home, loft conversion, ground level extension, new consumer unit, some new circuits and some circuits will be extended/modified. I also will install a PLC and control the various circuits with it while I'm away from home like heating and lighting probably incorporate some CCTV in to later as well.
Point is, would it be more cost effective if I gained registration to preform part P testing or would it be cheaper to get someone in to carry out the tests?
Seems a bit odd that 16 years after starting out in the industry I have to employ a spark to work in my own home but if that will be the cheapest way to get the bldg regs signed off that'll be the way to go.
Look forward to your replies
Lee
Lee
