part p question | on ElectriciansForums
Discuss part p question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
M
matt12321
came across this question today and was unsure
under the building regulations 2000, which projects are exempt from control?
a - the extension of a building by the addition at ground level of carport open on at least two sides
b - the provision or extension of a controlled service or fitting in or in connection with a building
c - work involving the underpinning of a building
d - the insertion of insulating material into the cavity wall of a building
Welcome to Electricians Forum | Electrical Advice Forum | An electrical forum for electricians in the UK!
Hi matt12321 and welcome to electriciansforums.net!
Upvote 0
No worries bottom of the page you will see forum jump use that to select the forum you want then on top left side you will see a button new thread click that and away you go.
Hope that helps
Chris
Upvote 0
Reply to part p question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Amazing, very informative and brilliant system.
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
Electrical Courses
