part p | on ElectriciansForums
Discuss part p in the Business Related area at ElectriciansForums.net
M
mick21
Hi all,can someone out there tell me if you have to be part p if you are undertaking work in a shop where somebody is living in flat above.
From the Electrician's Guide to the Building Regulations page 16 1.3.2. Scope of Part P
"Part P applies to electrical installations in buildings or parts of buildings comprising;
item (ii) dwellings and business premises that have a common metered supply - for example shops and public houses with a flat above with a common metered suply.
The converse is that if they have seperate meters then Part P does not apply to work in the shop.
Cheers
Will
Reply to part p in the Business Related area at ElectriciansForums.net
There's a tax advantage of starting sole trader and growing a business you eventually hit a limit where you can't earn much more. (Once you have...
Isn't it just a little sad that it should cost sooooooo much to LOG a few jobs to BC.... O where did it all go very wrong ? Signed Man in tights...
