At the origin, I have 25mm tails split to two fused switches. One 63a fuse protecting a 16mm (3 core SWA) submain to a DB (100a main switch RCBO board) at one side of the property and one 80a fuse protecting a 25mm (3 core SWA) submain to a DB (100a main switch RCBO board) at the other side of the property.
My question is about certification. The section "Particulars of the installation referred to in the certificate". Would I have to do one Certificate for each submain to it's final DB. So treating each as it's own installation?
Also what should I be quoting when filling in "supply conductors, main earth etc." I would be assume supply conductors and main earth to the final DBs (SWA) not the tails to the fused switch?
Thanks you
Thanks you
