PAT adapter??? | on ElectriciansForums
Discuss PAT adapter??? in the UK Electrical Forum area at ElectriciansForums.net
The Kewtech Pat adaptor may be sufficient to get you started (I have one in my tool kit) if your only testing up to 50 items, beyond that it becomes a real pain and is much easier with a dedicated PAT.
Because the adaptor relies on an MFT to drive it, when doing the earth bond test you are limited to the output of the MFT on it's low resistance ranges, approximately 200mA. That is not ideal for testing Class 1 equipment where a hard test at a maximum of 26A is more appropriate, but it still complies with the Code of Practice and is similar to most of the battery driven hand-held PATs on the market.
http://www.kewtechcorp.com/sites/def...apterflyer.pdf
Reply to PAT adapter??? in the UK Electrical Forum area at ElectriciansForums.net
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
throw the phone down the moment they mention PAT testing !
