PAT Fuse rating | on ElectriciansForums
Discuss PAT Fuse rating in the The Welcome Forum area at ElectriciansForums.net
C
chris.hyom
I am an unpaid volunteer at a charity shop in Llanelli and I do PAT testing for them when I am not needed at work. I tested a Hotpoint Iced diamond RFAA52 fridge freezer, the plate on the back said 150 W but it had a moulded plug which said 13 amp. I went on Hotpoint's web site and found the instruction book which said 13amp. I was torn between following the plate and fitting a 3amp and following the instruction book. In the end I left the 13 amp fuse in the plug. Was this the right choice, I have noted lots of moulded plugs which have to high a fuse for the appliance and have changed them for lower fuse ratings but now I think this must be the wrong thing to do.
Personal;ly I'd always follow Manufacturers instructions, but I guess it comes down to the size of the flex more than the motor rating.. if it's clearly a .75 3 core it's going to want that 3a fuse in.
Reply to PAT Fuse rating in the The Welcome Forum area at ElectriciansForums.net
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
