PAT Test MInibelle mixer?! | on ElectriciansForums
Discuss PAT Test MInibelle mixer?! in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
R
Robby Rotten
Hi All
I have recently qualified as a PAT tester, for doing in house stuff for a building company.
Does anyone know how to PAT test a cement mixer with a magnetic start?
I was told on my training course that you could buy an adaptor for such purposes but I have drawn to a blank where to get such a device.
Any advice would be appriciated.
Many thanks.
are we talking 110v adpater
[ElectriciansForums.net] PAT Test MInibelle mixer?!
HI Duane. No. I was told that you cannont do a test as the switch is magnetic and cannot do a test with a battery operated PAT tester. I have a Metrel Im3311 which runs on batteries? Thanks for your input. :)
Hi All
Many thanks.
Give them a call and ask them where to buy one?
Is your concern that the Metrel only does a substitute leakage test at 30V so neither that nor the IR test reach the motor as the contactor can't be energised? Have you checked whether it is indeed a contactor or a manual NVR, as the latter can be held closed to get the IR & SL tests to the motor? What is your normal procedure for testing loads with functional switching of major internal components, when using a tester that is incapable of energising the controls?
Reply to PAT Test MInibelle mixer?! in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I used to do a lot of this. My go - to was testing at the load side of isolators etc where possible. Although of course you'll find plenty of...
Hello Dave, Thanks for taking the time to reply. I appreciate the info, I haven't updated this post yet, but I have since been talking to some...
