Pat test pass for items with USA plugs and cords | on ElectriciansForums
Discuss Pat test pass for items with USA plugs and cords in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Should the the items have passed the "PAT" test?
  • Total voters
  • Poll closed .
UKMeterman
Hi,
Could you explain to me how these two items could have passed the in service equipment examination and test. Both items have USA two pin plugs, and one is on USA zip cord. The item is being used in the main hall at Hampton Court...
You have to apply common sense. If it's fit for purpose and passes all tests and the inspection then I would have no problem.
You test it whilst plugged into the adapter. It's like the testing I was doing the other day. I was busy unplugging every thing from the multi gang behind the tv and working out what went to where. Then the tenant said the last bloke just plugged the multi gang in to his tester and tested the lot in one go.
I would say its ok as long as a suitable coverter plug is used mind you the item on the picture looks like the flex does not have any outer sheath so I may not of passed it if that is the case
I'm not used to seeing single insulated cables like these used on anything beyond speakers (nowadays). Is figure 8 single insulated flex part of a cable standard approved for this use in U.K.? If not, wouldn't that be sufficient grounds to fail the inspection?
This is a good question.
They have both, high drain appliances are 220V+ e.g. AC. Different fitment plugs/socs though I think so yeah, what is that lead supplying?
Reply to Pat test pass for items with USA plugs and cords in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
