PAT Tester for Testing 110V tools and extension leads | on ElectriciansForums
Discuss PAT Tester for Testing 110V tools and extension leads in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
M
Megahertz
I've been asked a lot recently about testing 110V appliances, and the best PAT Testers to use. Most people seem to be using a battery powered tester (such as a Seaward PT100 or similar) with a home made adaptor - not ideal.
I've just written an article covering the main points and I post the link here in the hope that it's of use to members!
Of course, I'd welcome any feedback.
Choosing a PAT Tester for 110V tools
Tim
I've got a metrel unit which tests 110v units BUT what Metrel don't tell you is that you need to plug it into a 110v transformer to use it to test 110v units!
Tim
Some refreshing comments on your site, one of mine for you though, the recommendations for "PAT" on appliances are set out in the IET CoP & HSE documents, so they are possibly more strictly "suggested" then those in the GN3, which is not statute law, is not a BS and is merely IET interpretations...
Reply to PAT Tester for Testing 110V tools and extension leads in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
"When stoned..." Brilliant!
