Hi just trying to get my head around how to go about pat testing a 3phase 415v 4 pole extension lead, on the first test (IEC polarity) it looks like it needs to see a closed circuit on each pole being L , N , E independently, obviously there is no neutral connection as it stops at the commando plug, do we have to connect the neutral outside of the commandos to get a correct reading. The pat tester is just faulting out with open circuit.
Currently connections are as follows, 230v plug live to live in commando socket lives L1,L2,L3 linked. 230v plug earth to commando socket earth, 230v plug neutral ( no connection to commando socket)
IEC socket live to commando plug live and lives L1,L2,L3 linked, IEC socket earth to commando plug earth, IEC socket neutral (no connection to commando plug)
If you are using a standard PAT tester, it will always fail Polarity as all phases are connected together. There's a youtube clip by PAT-iT How to test 3 Phase on an Apollo 600. pretty much explains. As James explains, a multi meter would confirm polarity just using the Beep Test
Don't link the three lives together for the test as that could still appear to pass with various faults on the lives.
If two of the lives are swapped at one end that would appear to pass, if one or two of the lives have no continuity it would also still pass.
United Kingdom
Pat testing - 3phase 4P extension lead
Electrical Testing & PAT Testing Forum
Thread Tags
tomodo,
Brother Blue,
