d3jpt
Hi ive got a pat testing job to do in a pub and it has about 30 disco lights, some led and some bulbs, how would you go about testing these.
Cheers
Cheers
Discuss pat testing disco lights in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
sorry should of said im worried about the IR blowing the bulbs,
In that case test them as they are IT equipment as the 26amp earth bond test could damage them also you could reduce the voltage and test them on IR at 250 or test with the L and N shorted , the test between this and earth
on-off-on-off-pass-fail-pass-fail
Cheers
Reply to pat testing disco lights in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
