pat testing it equipment | on ElectriciansForums
Discuss pat testing it equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
C
colinhills
hi all please help
i hvae been begun pat testing for me company as i am on the only one with the certification. but would like to know if i am doing it right.
on the computer base i am doing earth cont and the then factuion linkage
on the screen i am doing a leakage test
on printers i am doing leakage and the same with laptop leads and phone lead
is this correct or have a lost the plot.
I think your plot is getting a weenie bit lost - you say you have certification, but for what?
1 PC processor (base unit) : Visual - Earth bond at 100mA - then insulation test.
2 PC Monitor (screen) : Visual - Earth bond at 100mA - then insulation test.
3 Leads for both these would then be tested as extension leads : Visual - Earth bond at 25A - Insulation then Polarity.
4 Printers : depends if mains fed or powered via an AC adaptor. Mains fed : if Class I as per above,
5 If Class II : Visual - Insulation, then Touch Leakage. If from an AC adaptor : Visual - Insulation then touch leakage, and if lead is 3 core test (it) as extension lead.
6 Laptop : Test AC adaptors as in 5 above - then if leads are 3 core test again as extension lead.
Hope this helps. Better get Code of Practice Ver 3 if you don't already have.
What type of phone leads are you encountering or are they power supplies for phone systems?
Reply to pat testing it equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
out of interest UK, how do you know what kit is connected?
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
