PAT Testing - Powerline Adaptors? | on ElectriciansForums
Discuss PAT Testing - Powerline Adaptors? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
K
ketanc
Hi all
Have been approached by my employer to try and determine if a product we use in consumer's homes needs to be PAT tested.
Its a Powerline Ethernet adaptor with a mains pass-through (Comtrend Powergrid 9020) -- see link below
http://www.comtrend.com/links/114$product.htm
It is marked as double insulated, but the socket extension pass-thru is throwing me off.
Any advice greatly appreciated :)
Thank you all in advance.
Kay.
double insulated, low risk, formal visual recorded inspection.
BUT
as it has a mains pass through socket I would treat it as an extension lead, albeit a very short one.
Must test that earth continuity.
Reply to PAT Testing - Powerline Adaptors? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
out of interest UK, how do you know what kit is connected?
