PAT testing Qualifications | on ElectriciansForums
Discuss PAT testing Qualifications in the UK Electrical Forum area at ElectriciansForums.net
Heathrow
Hi guys, first of all, really sorry if it's a daft question but I'm having a bit of brain fart.
Recently I received some calls (for the first time) about PAT testing for couple local businesses.
Never been bothered doing PAT, but seems like it might be good option to attract some good customers in the future.
Do I need specific PAT quals to carry PAT testing?
I obviously have my L3's, 2391 and regs.
Thanks for any explanation.
Not necessarily but you need to be familiar with the latest code of practice, 5th edition.
There are city and guilds qualifications for "in service inspection and testing of electrical equipment" (the term "PAT testing" is no longer officially used or even mentioned in the code of practice). I would recommend getting a qualification if you're going to be doing this regularly, but competence to do the job properly and safely is all that is strictly needed.
I did the C&G course on it 8 weeks
8 weeks? Is that a mistype? It's only a 2 day course I think.
As above, get the latest code of practice. And make sure you know what tests you are carrying out and what results to expect. I've seen a few people doing PAT/ISITEE who didn't have a clue that the test they were doing was pointless, but because the machine said 'pass' they thought all was OK.
It was a 8 week course @ night 2 hrs a night very very boring
Think mine was 3 days but that was 25 years ago.
You really need to be doing the course IMO. It’s not really needed if you are already a competent spark and can read a book, but it will be helpful for the detail.
A qualification helps to prove competence if ever needed.
Fully agree. I once spoke to a spark who didn't realise that the PAT/ISITEE test machines connect line and neutral when testing. Meaning the leads they were testing were getting absolutely no testing done in reality. So someone who is not from an electrical background really ought to do the course before merrily pressing the test button and seeing the pass indicator light up.
The visual inspection is the most important bit, however one does also need to electrically test and know what you are doing. I remember doing a mag mount drill, clearly marked with double square on drill to show class II, but the base was clearly class I and it seems it had been tested many times with the earth wire not connected, and passed.
Also size of a portable appliance, did a batching plant clearly portable is was moved around site to site with around 10 articulated units, but took around 3 days to test, OK extreme case, but items of equipment may not have 13 amp plugs, and can as a result take longer to test, the hand drier in the toilet springs to mind, which really needed two people.
So how to price, or limit what is tested? Freezers I would hope single pole relay for the defrost heater, but with inverter drives today really these items need to be tested by some one who can repair them, and understands how to test without causing damage and also test all parts. Same with washing machines, how can one test a part which only runs at the end of the cycle without sitting there waiting for it to complete a wash?
So the contract needs careful wording, items with thermostats or timers need to be tested by personal would normally repair the equipment. Where I worked the cool drinks machine, etc were on maintenance contracts and the service engineer was responsible for testing and inspecting.
And some items would be tested with the installation rather than the rest of PAT testing as could not use the PAT testing machine. I had to do PAT testing but it was a boring job in the main which I hated doing, and caused all sorts of arguments. For example can one put a label on a hand tool saying tested and passed if a guard is missing? It is electrical sound, but mechanically dangerous.
The 370 watt rule was the other point, many hand tools can be latched on, and the motors are over 370 watt, so rotating machines rules kick in, can you pass the item when it does not comply with 552.1.2 when it was designed that way by the manufacturer? Same applies to grinding wheels, I use to use active RCD's to stop restart should power be lost and then return.
But it is not cut and dried, even the desk lamp without the double square sticker, you know it was designed as class II, but no sticker to say class II, likely made in China, and you have to decide if to pass or not. Unlike the EICR where you can write out an advisory note, you only have two options, pass or fail, use common sense and pass it, and next inspector may fail it, and you have to explain why you passed it.
As to central heating, with pumps, thermostats, and control boxes which are all in service electrical equipment, where do you draw the line? So a thermostat fed with flex where the green/yellow has been used for line, is that part of the installation or part of the equipment as the flex is not fixed?
From the first time I did inspection and testing there has always been that argument, what is part of the installation and what is considered as equipment.
In house easy, you are told what to test, there are no grey areas, but as a contractor what do you include? I have seen contracts which state must be fitted with a 13 amp plug and not include timers or thermostats. The question is who is the manager? The tester and manager do not need to be same person.
Also can you earn enough? With a Robin at that time top of range PAT tester I tried timing myself, on average including walking item to item it took around 6 minutes per item. Specially when the tester did it's self check. So at ÂŁ10 per hour, that's ÂŁ1 per item, clearly not enough, even in 1995 my time was charged out at ÂŁ25 per hour, so ÂŁ2.50 per item, and the market was flooded with people charging a ÂŁ1 an item.
Yes you can have a roll of labels pre printed and just give each item a quick look, and no obvious faults stick on a label, and the modern battery powered testers are a little faster, but in the main PAT testing is a loss leader, a way to get ones foot in the door, can you afford the time?
Reply to PAT testing Qualifications in the UK Electrical Forum area at ElectriciansForums.net
My older card has it but my newer card doesn’t
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
