Pat5 | on ElectriciansForums
Discuss Pat5 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
Pat5
Is there a plug in socket tester that shows neutral earth reversed
I don't think one exist
never seen one myself. they don't make em so as we have to take the socket off and have a look see.
IF YOU CAN'T SEE MY MIRRORS, THEY MUSTA FELL OFF
we prove our earth connection via a wandering lead on all class 1 fittings and at the same time the terminal screw on fcu, skts and alike.
proving your earth this way then using your martindale proves your polarity across all three conductors.
matine dale do 1 where the L-E lamp is dimmer than L-N which is ment show that the earth path is a higher resistance but I have never seen one in the shops
Reply to Pat5 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
