G
Geordie Spark
Lenny!!!! the translate button dont work?
Here ye gan bonny lad
Whey naar man, we got noo fangled pipes n bogs in the hoose n aal that marra.
It's berra thin Gatesheed doon in shields
Nice try Darkwood, it's good burrits wrang man
Aas gannin forra borrel o dog
Spot on you'll find as its broad yorkshire, nar thassa proper talk wi isa --- from lad.Nice try Darkwood, it's good burrits wrang man
How man wuve had it fo donkeys niw man, wuve got chorches anaal yeknaa wi propa christianity niva fash mesell wirrit thoughbut, aave had choclit fireguards that wis mare gud
Nee botha hin. Cauldun ora waamun?
Aye, Aave gorra torbine an a genny runnin yeknaa
Naar man not them torbines! Torbines wot drive gennys ye heedthebaal
You southerners are crazy
Tykes not propa taalk man, it's ownly Geordie wirrits brains kicked ootSpot on you'll find as its broad yorkshire, nar thassa proper talk wi isa --- from lad.
Divvint yee start owt bonny lad Aal waam ya lugs if ye divvent lukootYou southerners are crazy
Tykes not propa taalk man, it's ownly Geordie wirrits brains kicked oot![]()
As already been mentioned numerous times, you are llacking essential basic test equipment and thus unequiped to solve this issue also i will head you on what i believe is a big suspect here in that im guessing one of the lighting control ballasts is faulting, it wont show on testing but also will work as normal until ballast has heated up sufficiently to expand its metallic structure where a fault is then created, this rings bells with the time to trip etc but to eliminate other possibilities you do require an IR tester and a clamp meter, its been mentioned several times and if you are qualified then im totally bemused why you cant grasp this and what exactly you expect to find fault wise with a multimeter and a volt tester.I have Test equipment, Voltage Indicator and Digital Multimeter. Just not a Low reading Ohmeter and Insulation resistance meter. `
Is my analysis of interest or am I off topic? How To Become An Electrician (temps pour le chapeau d'étain?)
