PDF. customer. unit | on ElectriciansForums
Discuss PDF. customer. unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
william7093
Hi all. Has any body. Got. A PDF. For. Customer unit. That I can print out. If not. No worries. Will make one up. Thanks in advance.
So this explains the low install rates these days. Your just going around sticking up pictures of CU's on the wall and drawing on cables with a sharpie aren't you!!
I KNEW it!
I could do a pdf for a Custard Unit. or do you mean "customer you nit!" I've had a few of those as well. But Consumer Units you would need to be a bit more specific about! lol.
I'm guessing he means a legend that he could stick inside?
As for the full stops, I wouldn't mind betting he is tapping the space bar twice on his iphone...
Reply to PDF. customer. unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks for the advice, I actually had no idea about the HMO licensing rules so have learnt a lot. Just did a search, its not licensed as an HMO...
Hi everyone. Does any body have a timesheet pdf they use for theyre staff to log there weekly activities? :) Thanks
