PE insulated and PE sheared | on ElectriciansForums
Discuss PE insulated and PE sheared in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bghayad
Hi All;
Is there a cable who is PE insulated and PE sheared? How it will be insulated and sheared?
Regards
Bilal
This is what they need, can u provide? But if u can explain for me the insulated and sheared:
Under ground telephone cable 0.65 mm pe insluated and pe sheared 200 pair 1000 mtr one drum.
What is ur price?
Regards
Bilal
Well, really I am caring to know what is the "pe sheared", I know the pe insulated but did not hear in pe sheared, anyone can advise and explain what is pe sheared cable?
think he is on about polyethylene sheathed,probably looking for P E U T polyethylene unit twin telecoms cable if my memory is correct.strange thing to ask for here.
Reply to PE insulated and PE sheared in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
Mixer tap ring sheared during seal replacement - how remove In serious trouble here, was going to replace seals around base of mixer tap spout as...
Barnjet
B
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
