Periodic inspection and testing label. | on ElectriciansForums
Discuss Periodic inspection and testing label. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
hi there
when you add a circuit to a C.U. where there is no existing label for when it was last inspected/tested, is it permissable to place your own pir sticker on the C.U. without carrying out a EICR. if you write UNKNOWN (last inpection) and ASAP (next inspecton) or is there another way ??.
and the RCD label , of course. along with the no cpc on lights, shared neutral, go to jail, do not pass go, do not collect ÂŁ200.
I agree with murdoch put stickers on in relation to what you have done, i only put test label on when I've fully tested installation, general write on test sheet overdue periodic
Reply to Periodic inspection and testing label. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
No it is not implying it is safe, it is stating what the recommended date for the next inspection is. The next inspection date sticker doesn't...
davesparks
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
