periodic inspection report no access to the consumer unit | on ElectriciansForums
Discuss periodic inspection report no access to the consumer unit in the UK Electrical Forum area at ElectriciansForums.net
sparky928
Hi Guys,
Got to do a periodic inspection report, there two consumer units one i cant access due to kitchen units in the way i can see the breakers but i wont be able to take the cover off and the other consumer is fine to get to.
Any Ideas what to do for the consumer unit i cant get to? or what to write on the report?
All you can do is verify the circuits and give Zs and rcd readings if applicable. On the schedule of tests you can only complete the parts you know, the rest can only be NV. You can only do what you can and decide how you are going to Code it in the Report.
hum..... so 50% of the installation not really in a position to test, is it worth doing?
And what code for inaccessible CU? C2?
Inaccessible cu not even able to open the cover, thats a C2 if there ever was!
I would instantly think C2 as well but then I thought what would I say if I was asked to justify that with regards to it being 'potentially dangerous'?
The CU and all circuits may be in excellent condition. Perhaps a 'limitation' with a strong recommendation it is made accessible for testing?
Or perhaps a C2 because it is potentially dangerous as electrical installations should be tested every 10 years and this one can not be?
Reply to periodic inspection report no access to the consumer unit in the UK Electrical Forum area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
