Periodic inspection report on NIC EIC software | on ElectriciansForums
Discuss Periodic inspection report on NIC EIC software in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sparkydan
Hi
Is anybody using the NIC EIC certification software to complete periodic reports on commercial buildings with a large number of db's? im not getting on with it as you can have an observations page for each db just wondered how others get on with it?
Thanks wire puller
I think it would be better if each DB had its own page like you can with hand written forms how do you reference each DB with it? do you add an observation then use that line to put the DB name?
Reply to Periodic inspection report on NIC EIC software in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
