periodic sequence | on ElectriciansForums
Discuss periodic sequence in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
onmyway
Hi can anyone tell is the correct sequence of tests to do on a periodic in college as ive got my practical exam Tuesday and just wanna make sure ive got it rite. Cheers.
I'm a bit worried you dont know and its 2 days away :S
GN3 is a must on level 3 if you ask me, You should be told to buy this book at the start of the year IMO.
Strangely you not allowed to have it with you on any practicals :(
Its probably because its written in plain old English in GN3 and a pain to find in the Regs.
Try and blag a GN3 tomoz mate is my best advice, If you get stuck pm me and i ll scan it in for you and email it.
GN3 page 33 gives the sequence of tests that you can use as a guide, but as above in a PIR you can test in any order.
Appendix 7 osg page 151 covers PIR's also read the entire appendix 3 as well for a full understanding of testing. Good luck.
I ment I'm sending you my email address. I need to clear some room on my phones memory. I'll have to check what I have on it atm, loads of bpg's but it will be handy to have the GN3 in my pocket at all times need a smaller copy.
Reply to periodic sequence in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, Ive got a couple of Megger PAT 450 testers, and, for a number of reasons, Im not happy with the printer it comes with. Does anyone on here...
OK. Thanks, maybe I'm just panicking. 👍🏻
