Hi,
My 2010 5008 semi automatic 1.6 Diesel intermittently goes into limp mode where only 1st 2nd & 3rd gears are selectable.
The dashboard display states ‘gearbox fault’ and the ABS light is illuminated.
The following fault code came up on the diagnostic equipment when I took it in to be checked over:
‘P0559 brake signal (switch CAN) coherence’.
I was recommended to replace the foot brake switch. I did replace it but the fault still remains.
I would really appreciate any advice or recommendations about how to go about fixing this issue.
Many thanks!
Many thanks!
