P
pushrod
I know that often people will just test PSCC as that should be higher than PEFC so test between L1 - N, L2 - N and L3 - N then take largest value double it and record that value. However was looking through the user guide for the 1552 and noticed that you can test phase-phase pfc. Does this mean that you would just test L1-L2, L2-L3, and L1-L3 and just record the highest value ie not double it.
If correct would you be allowed to do this in a 2391 exam (it would be more accurate?) or do they prefer the L-N and rule of thumb double method.
cheers
cheers
