Phase angle controllers | on ElectriciansForums
Discuss Phase angle controllers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
JonAW
Hi Guys
I am using the below product to control a small vibrating feeder. The control input I have is a 4-20mA sourced from a plc. The spec sheet seems to only show a wiring diagram for the analogue voltage control and not the analogue current control.I was hoping someone on here could help. thanks
Product: Crydom | Relays, Switches and Indicators | Relays | Solid State Relay | Proportional and Power |MCPC2450D
Spec sheet: http://docs-europe.electrocomponents.com/webdocs/0b69/0900766b80b69c75.pdf
I think you need the 4-20mA input to P2 negative and P4 positive.
It may be worth a call to their tech department to check though as you dont want to blow the controller.
P1​
8-32Vdc (+)
P2​
Ground (-)
P3​
ON/OFF Control
P4 0-5V, 0-7V, 0-10V, 4-20mA
Reply to Phase angle controllers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
