Phase shift starter | on ElectriciansForums
Discuss Phase shift starter in the Commercial Electrical Advice area at ElectriciansForums.net
My house
I'm currently messing around at home don't worry all safe and isolated etc. I got a baby 1.1kw motor from work as I'm in a domestic house of course only single phase and I'm not cheeky enough to find a spare inverter at work for it to work! :D But I'm making a little starter using some capacitors start and run caps I asked a one of the at work and he recommended 30uf per HP for run and 50uf per HP for start. But anyway my question arises that I'm running them via separate contactors for the run and start via a timer and that will initiate the change from start to run, so I have essentially my Live, Neutral and Capacitor 'phases' is it a better idea for me to have the capacitor on the supply or load side of the contactor? I'd guess or assume on the supply so it's already charged? Any other CONTRUCTIVE criticism would be helpful if I'm not doing this right! :)
Here is the beast, not! But yeah just a normal 3ph 4 pole motor. Was spare and never going to be used so asked if I could have it! But yeah seems fine just gonna wire it up in delta. Cheers for the reply marvo.
Reply to Phase shift starter in the Commercial Electrical Advice area at ElectriciansForums.net
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
