P
peteludman
just want to check about sockets close together on different phases or can you plug things in on different phases?
the problem is that servers have 2 power supplys for backup if the power goes then the ups takes over but i have just installed a 15 kva ups to feed the DB (which i said was not big enough in the begining) 20A per phase , because the phases are on three seperate walls of the server room and on 1 phase drawing 19 A it blew a trip.
so what they have done is run extension leads round to spred the load so each server is fed from 2 phases 400 v
can i just put different phases next to each other if i just lable the trunking?
