Heh, not caught in any storms just try not to get too addicted to these yer tinternet forums, so I'm not on it more than once every few days.
Are you saying you don't know how to test for continuity??
It makes no difference to the working which colours you use - so long as 2 goes to 2, 3 goes to 3 etc. but the normal convention is:
2 Blue with white stripe
3 Orange with white stripe
4 White with orange stripe
5 White with blue stripe
The greens will go to terminals 1 & 6.
Cheers for that mate. I do know a bit about inspection and testing as it goes... I just don't have a clue about phones, but since I was asked to connect up an already installed cable at the same time as doing some lighting, I thought how hard can it be. I connected it up exactly as you said funnily enough, but nothing. I never considered using the fluke to do a continuity test, but I suppose there's no reason why not other than it will be fiddly.
Measure the voltage, you should have 50v dc, will give you a idea where the break is if you measure at every connection point.
Between which two cores should I get 50v?
Find the other end Capn Ahab and ensure that the the terminal numbers and colour codes match, you say that the cable was already pulled in so are you sure it is connected at the other end?
Also if it is part of a cabinate installation you may need to fit a patch lead at the cabinate end to make your outlet live.
It's definitely connected as I did both ends. It might be wrong in the cabinet I guess.
You say: "there are several phones dotted about" This may mean they are part of a system whereby one phone can call another in the supermarket i.e. till operator to manager's office.
If this is the case you'll probably need ALL the cores connected at all the sockets.
This is the bit where I get out of my depth, as I would not know how to test/design/figure out this kind of system. I have a couple of ideas as to what it might be thanks to the advice on here so I'll have another crack when I next get back there, but if none of it works, I'll admit defeat and advise the customer to call in someone who knows more about telephony than me.
Cheers for all your responses chaps. Very helpful as ever!!
One final thing - if I wanted to read up on data cabling and phones, where would you point me? Book, web, short course??
Thx :rockstar:
