What size of GDT would you fit and where?
A discussion requires numbers. A surge may even be hundreds of thousands of joules. A protector that only claims to absorb hundreds of joules does what? Protection is always about where hundreds of thousands of joules are absorbed.
Will a 2 cm part inside a protector stop what 3 kilometers of sky could not? Of course not. Will that part somehow absorb hundreds of thousands of joules? Of course not. Those other protectors are only for a completely different transient that also does not harm modems and routers. Modems and routers already contain superior protection.
A surge that actually does damage must be absorbed by earth. Just like a lightning rod. Does the rod do protection? Of course not. The rod is effective (for structure protection) because it connects a surge harmlessly to earth. A protector is effective (for appliances) because it connects a surge harmlessly to earth.
Master sockets once contained these well proven solution. No longer because surges are so rare in the UK. Many are willing to just replaced damaged parts. And believe hearsay that nothing can protection from such events.
BT's switching computer is threatened by about 100 surges with each storm. How often is your town without phone and DSL service for four days? Never? Because BT installs this earthed protector on every wired BEFORE it enters the building. You need same on the master socket.
Classic examples are on page 10 of:
http://bourns.com/data/global/pdfs/bourns_osp_product_guide.pdf
Unfortunately even it is useless if not properly earthed. And best installed as far as possible from electronics (ie in the master socket). Unfortunately, rules say only BT can install it.
Protection is never provided by a protector. Either a protector connects low impedance (ie 'less than 3 meters, no sharp wire bends, etc) to single point earth ground. Or that protector only protects from another type surge that typically causes no damage. This rule applies to every incoming wire - not just telephone / DSL. Every wire must connect to earth either directly or via a protector before entering the structure.
These concepts have been proven by over 100 years of science and experience. And is why BT's $multi-quid switches remain unharmed with every storm.
