G
Gary Qt
Hi, newbie so go easy!
Have some outside hardscaped LED strip lights. Looking to add in a photocell dusk to dawn with timer function so I can have them come on at dusk and switch off at say midnight. Also however looking to add in a security aspect where I have a couple of PIR’s which will then switch the lighting back on again should it be past the set off time (midnight) for a couple of minutes.
I can find timed dusk to dawn sensors and plenty of PIR’s out there, however does anyone know of a single product that will do both? Guess I am looking for some kind of lighting controller that will take a photocell and PIR sensor input.
Failing this any reason why, since I am using LED’s I could not run the photocell timer in parallel with the PIR with some diode protection to stop backfeed from either sensor (see below / attached for what I mean)
Many thanks.
Many thanks.
