good morning all, I’m looking for a little advice regarding an existing PV install, I’ve just waited a property where a PV install exists (working no problems) my question is on the correct connection to consumer unit, the PV is connected as was with a 2.5T+E from inverter you consumer unit via DC iso and 2 x AC (one local to inverter and one at consumer unit end)
Stupidly I have disconnected the 1 way RCD protected consumer unit which fed the PV power to the main consumer unit and not taken a great deal of notice of the connections durrrrr!!!
My question is on the reconnections. This is probably going to sound simple to those who deal with this every day but I I’ve started to over think things and hit a mind blank. Could anybody post a simple diagram of the “correct” connections from AC iso through 1 way board to main board? Basically which side of RCD should PV go to before feeding my 16amp MCB in main board.
Thanks for any assistance, as I said I’ve over thought this for sure.
