N
Newsome3
Hi
Huh as anybody used the above items?
ive a communal area in a old Victorian house where there currently is the push timer switches
my problem is there all 2ways at present
whats option for me to do so can function well enough with out having to walk down/up dark stairs as changing all to 1ways will make that the issue
cheers in advance
Hi
cheers in advance
A little confused here, no need for 2 way switches with timer switches, 1way wired in parallel will work
I'm not sure to be honest I've not been to view yet just what customer has emailed me with
fingers crossed it is
just hope you've got neutrals at the switches.
Im sure my wholesaler has emailed me the info saying not needing
using b.e.g internal with battery built in aparebtly
Think be a no go job if need neutrals as customer says no neutral at them just live and switch live
It's a big old Victorian with old coving so won't want me doing and wiring alterations
The Danlers no neutral pir units are a peice of **** to fit, just make sure they are supplied with the cap you need to fit on the circuit
Pir 2 wire wall switch
Thread Tags
Newsome3,
not clever,
