- Joined
- Jan 13, 2010
- Messages
- 231
- Reaction score
- 56
Hi all
just after a couple of opinions on PIR codes
generally im using the ESC good practice guide as a base for my PIR coding but there are couple im not sure about:
this is for a factory:
A 3 phase machine isolator supplying 2 seperate machines (code 4)
A 3 phase circuit breaker supplying 2 pieces of equipment, they are totally different, one is a set of roller doors and the other is a saw (code 4)
A 3 phase machine connected without an isolator seperating all poles before the machine. (code 4)
None are particularly dangerous, what do you think?
Many thanks in advance
