N
nelson19
hello all,
what would you code a bathroom fan that has no isolator, fed direct from light fitting?
was thinking code 4 as does not comply but still can be isolated via mcb the same way you would isolate a light fitting etc.
also had to issue a code 1 for a db with enough room along the horizontal top surface to fit a small hand in. however i have been asked to do the remiedial work and wondered how id get around this without changing the board? cables are clipped direct above the db which makes boxing difficult. any ideas?
