just carried out a pir on 3 bedroom semi hager split phase board rewired 2000 the instalation is of a good standard and all readings comply with bs7671 few problems found were 3 bedrooms upstairs all with brushed crome spots looked in loft neat job done with cabling all into lighting jbs but no earth to crome spots what code would you use for this was thinking of code 2 myself but looking to see what you guys think also in the garage which joins the house t&e cabling clipped direct to brick work before heading under floor boards am i being a bit fussy snagging this as there is no mechanical protection what code would you use for this or would you accept it
