M
MvP Electrics
hi all,
was carrying out a PIR this morning on a 1 Bed flat. noticed in the bathroom the ceiling light fitting is attached to the shower curtain rail with string to hold the rail in place.
should I put this in my report? if so what code should i give it. only potential danger ive seen is if the curtain is pulled hard the light fitting will come down.
