Pir in a garage! | on ElectriciansForums
Discuss Pir in a garage! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
Pippyboy1916
been asked to do a PIR test in a garage, been to the job and was wondering how to go about taken readings on equipmen(2 and 4 post ramps) that is isolated by a switch and with is isolated by another switch, there is no way of opening up the equipment, how can i take Zs of Insulation?
Got me wondering!
You can add to the limitations box that you have done this to make it perfectly clear - "hoist circuits tested to final isolator only"
In the words of the great meerkat - "simples"
Reply to Pir in a garage! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
