C
coxyboy
I recently carried out a PIR on a pub. It had 4no. Fuse boards one in the bar area just for lighting - this board had no rcd protection - is this needed for a pub? And there was a lot of circuits doubled up or even three lines in one mcb - should I recommend that I upgrade the fuse board so each circuit has its own mcb. I know this is good pratice to do this but what code would I give for doubled circuits c3 or c2?
fuse board two is in the cellar and does mainly sockets and heaters. It is a really old fuse board with the big brown mcb's. Again I take it that most if not all these circuits need rcd protection? C2? I've suggested that the fuse board is upgraded with rcbo's for each circuit to avoid unwanted tripping.
Fuseboard three and four were in the living area of the pub ie the flat and rented out rooms above. These were both split load boards and the right circuits were protected by the right rcd,s as required. I think thinking of doing two separate Certs one for the pub which would be unsatisfactory and one for the living area that would be satisfactory with only a few code 3's. Is this the best way to do it and I'm I allowed to do this...?
Would be interested to see other peoples views on commercial testing as I don't do these too often whereas I do upto four domestic tests on a daily basis. Any opinions , views or advice would be very helpful and I would be very greatful.
Many thanks
darren
Many thanks
darren
