PIR motion light for garden | on ElectriciansForums
Discuss PIR motion light for garden in the Lighting Forum area at ElectriciansForums.net
Miguel_92
England
My new PIR light for my garden/yard arrived today but i was wondering how Wago connectors work within a junction box? The box is waterproof of course, but i only know how a terminal works. Can someone explain how you use them with wires? As i've got no idea. An electrician told my dad who bought the box they are used all the time for those kinds of lights. But someone will have to explain it to me if that's ok?. Thanks.
  • [ElectriciansForums.net] PIR motion light for garden
Is the circuit protected by an rcd?
In my kitchen i have 2 switches on one plug on the wall. One is for my kitchen light and the second is for that light i've just removed outside. I also have a light above my fridge (minus the bulb), but this morning i found that light has it's own switch. But i can send photos of the wiring again from outside, as i did a post here a few weeks ago enquiring about the wires etc.
a wago connects 2/3/ wires of the same polarity together. i.e. in a 3 way wago you may have 3 lives or 3 neutrals, or 3 earths. they are not like a choc block where 3 = L,N and E.
Thanks for explaining it to me. I put it up via buying a 3 way terminal, then putting the junction box right next to the wires because the outside wire had hardly any give in it at all. Massively shocked (pardon the pun) that the wires worked to be honest. When i first saw them i knew they weren't what i needed, but at least it's up and working fine?
Reply to PIR motion light for garden in the Lighting Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
That will work fine as long as the Pirs use relay switching, some don't.
