PIR on student house | on ElectriciansForums
Discuss PIR on student house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
keithbr13
Hi everyone, I have just received a copy of a visual inspection on a student house and one of the items high lighted for replacement is the immersion heater as it has no over heat cut out, is this necessary ? thanks
Yes, potential scalding situation.
This one really arose because, if the thermostat sticks and no overheat cutout, you can get boiling water up the vent pipe and into the header tank. If it's made of polythene, it may eventually fail and come down through the ceiling. I understand that a child was killed this way.
Reply to PIR on student house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
