A
aaelectric
Hi went to do a periodic report today on a property and found the following observations.I know the current recommended codes but what about the new c1 c2 c3.Main armoured from meter more than 3 meters with no isolator/fuseNo RCD protection on bedroom sockets or breakfast bar No blanks on fuse board No danger signsFuse board marked incorrectlyMain earthing terminal not fixed, hanging loose Although kitchen and outside socket have RCBO installed they didn't install on bedroom sockets, appliances smoke alarms and lighting. Most circuits at some point will be buried less than 50mm in walls etcWould you put rcbos for the lot?Wiring looks within 4-5 years oldWould you say isolator for main is to be provided by network provider.Also would you still use the old reports or is it law now we have to use the EICR Thanks
