PIR or EiCR | on ElectriciansForums
Discuss PIR or EiCR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
R4BOE
whats your thoughts on this we started a inspection no a premises in the last two weeks of december and due to the how we were able to isolated sections and boards for testing it was completed yestarday
we use amtech fast test so a lot of the schdules have been filled in the PIR format as amtech did not supply us with the new softwafe untill mid jan with only the BS format at the moment
there is 13 distribution boards on this so a lot more work involded with the shedule attached to each board
do we a) supply it in PIR format of B) in EICR format
only thing is HSE are due a vist end of the week ! and the client says they might want to see the document !
i know a lot of the NIEIC contractors are still submitting PIR format even for inspections done in january
any view welcome !
Reply to PIR or EiCR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
