Hi, I have lighting in the bathroom plus an extractor fan. There is one switch for the lights and one switch higher up for the fan. I installed a PIR in the bathroom and wnated it to turn both lighting and the fan in parallel to the switch. I fed the PIR from the fan's permanent F and took the return from the PIR back to the fan's Switched connection+ the switched F on the lighting. As soon as I switch manually I get a short circuit. Has anyone got an idea what the problem is??
