Spaced
Hi everyone
I have had a callout to replace a malfunctioning stand alone PIR unit.
The unit when acivated would just flick the lamp on and off regardless of the time control setting position.
The customer had advised me that the unit has been functioning correctly for 2 years.
Unfortunately the maunfacturers of this original unit have discontinued production with no like for like replacement.
The unit is switching a 100W tungsten lamp and a 16W 2D fitting.
I have now tried 3 replacement units, 2 BEG and 1 Robus and am still experiencing problems.
The BEG units would both function correctly with the minimum time setting which ran at about 6 seconds, however
as soon as this was increased the units function correctly twice and then stay on permanently.
The 3rd unit fitted was a Robus. This functioned perfectly coming on for the set 2 minutes approximatey 6 times but
has now ceased to operate.
The technical team at BEG thought that the problem may be due to the mixed nature of the loads ie one inductive and one resistive
and suggested fitting a capacitor across the 2D unit. The NIC advised that this may not be a suitable solution due to the control
gear in the 2D.
Any ideas or suggestions as to the cause or how to rectify this issue would be greatly appreciated.
gear in the 2D.
